X Type rear brake inbalance!
Chris G
Has anyone ever experienced rear brake in balance on 2.2D X type?
Pads & discs ok.
Have freed up caliper slides,  stripped down unit and checked piston etc all ok, & Bled off brakes.
These faults showed up on mot test both wheels will lock up but the r/hand one requires 50% more force on pedal to lock it up.
Any info would be appreciated.
Chris G
Hi Chris,
there could be many different reasons for brake imbalance.
  • Faulty caliper (internally)
  • Weak brake hose (balloon'ing out when pressure is applied to it)
  • Pads not free to move with caliper cradle
  • Pad lining material (surface) defective
  • ABS modulator faulty
...to name but a few!
You could try swapping the pads to the other side to see if that improves it or makes it worse.
Otherwise, I would suspect the caliper as being faulty
Hope this helps?
Regards,  Trevor
Hi Trevor,
Thanks for your reply.
I fitted a new caliper which then brought the braking back into balance, and a mot pass last week I had  checked most of the other points you suggested, many thanks for your reply.
Chris G
