swapping stereo for single din head unit. Does any one know a link for the removal.
thanks for that trevor, off work tomorrow going to give it go. cheers
Just be careful of one thing. If you have a manual gearbox, you will have to pull the leather shroud around the gear lever out of its mounts. The clips are metal.
When you unscrew the climate control unit and pull it down to access the cables behind, it will rest on the gear lever, where the metal clips will scratch the display! Just like mine did! Thankfully, £25 on eBay for a replacement! :-)
Car stereo 2
Car stereo 3
Car stereo 1
Thanks for the video again, it was a big help. Was not to hard, just not to happy with the fit(cheap ebay item) apart from that I'm happy. Added a couple of other bits i can't live without. ;)
