I am a bit worried about the heater controls on my 2008 X-Type 2.2 diesel SE.  If I set the temperature to a comfortable level but then adjust it (up or down) on the display, the actual physical temperature seems to go either very cold or very hot.  I don't use the Auto function and rarely use air-con, so can anybody advise on what might be the problem?  Should I be letting the Auto function do its job, or might there be something more sinister going wrong?
TIA,
Mac
Hi Mac,
Jaguar recommend that you keep the climate control in auto, which I do, and find that it does its job very nicely.  See how it works for you.
