THE AIR BAG DASHBOARD LIGHT ON MY '54 S TYPE, DRIVERS SIDE, DOES NOT ILLUMINATE - BEFORE HEADING FOR A CODE READ ETC, IS THIS A COMMON PROBLEM WITH AN EASY FIX?
REGARDS .. JOHN
I'd be more concerned with your cap lock button on your keyboard, tha nahs..
only joking.
The only way you'll find out if there's a problem is code reading I'm afraid.
When you say it doesn't come on do you mean on startup?
any fault would be displayed in the lcd bit.
Welcome to the club, John.
Andy has given you the answer.
I am assuming all the other lights come on on startup.
Many thanks for the response(s) guys ( and yes Andy CAPS off) - clearly as I presumed a code read is obviously required and in reply to Peter, all other lights are OK.
Regards .. John
    • Jaguar Icons
      • 11 replies
