Remote control locking not working
Oldmanam
Hi, searched the site and couldn't find resolution on my issue.
Remote control key fob works for unlocking, boot opening, and lights. However when trying to lock it it doesn't work, had been working ok before. this is affecting both keys.
Any ideas on how to fix the problem.
Tried to re program keys, but couldn't hear the confirmation beep.
If both keys appear to have the same problem, I'd be thinking a fault in the door locking wiring Amardeep.
Do the doors lock from the centre console or by pressing the lock button on the driver's door?
Do the doors lock with the key in the driver's door lock?
As far as programming the keys. I've seen it done on an X-Type no problem but have never seen a successful attempt on an S-Type. I've tried all the combinations I have found without success. I won't say it can't be done but at the moment I personally don't believe it can be done ;)
Takes about 5 minutes with IDS / SDD diagnostics though.
Yes door locks from inside and by key, but not remote, also noticed that when pressing button inside to open the door and you hold it, it opens all four windows and when holding the button closes 3 of the windows, the forth you have to to close by pressing the correct button.
I've seen different combinations to do the 're programming I've only tried one of them so far.
I take the IDS / SDD diagnostics will pinpoint the problem?
