Glove box stuck on locked.
Hi, I have an 2005 X Type and the the glove box handle has come away with the compartment locked.
How do I open a locked glove compartment with a completely detached handle?
Any help is appreciated.
Thanks for you're reply Peter. It is a standard glove box in a standard 2005 x type 2.0L Classic.
I have found a couple of posts that may help.
Finally cracked it. Opened the locked glove box and removed offending lock. Now need a new handle. If I can't get a handle by itself  then I will have to replace the lock/ handle completely.
It's a bit complicated to explain how I did it. If I can find the time I will illustrate the solution with some photographs which might help others in the same situation.
  • 4 years later...
Did you ever post the pictorial explanation bob? I think they might be helpful, 🙏
