Cruise control warning / power dying
Cruise not available
Good morning
I have a 4.2 v8 06 s type that intermittently tells me that cruise control is not available if I switch off and restart the message goes away  if I don’t notice the message then within 500 yards the car loses power, but not completely poss limp home mode  again I turn off and restart with no further problems until the next time
do you have any idea what the problem is
you need to get the code read, ideally Jaguar IDS/SDD
generic code readers on read engine codes and sometimes give you wrong code
could be something as simple as a abs sensor, as they are tied into transmission and can cause your symptoms
but its all guess work till you get it plugged in
Had the battery replaced ( the original)this morning and everything works fine.
the techie queen at GIBBS in Braintree sorted it straightaway and cleared all the other faults that were showing on the diagnostics  worth her weight in gold that girl
many thanks for the advice
