Hi everyone, the other day my mums s type broke down.
I've attached her timeline of what happened.
She got it recovered and taken to a garage (just a general garage), they really weren't helpful and just told her it was f***ed. And said it probably Was the big end gone.
I went and talked to them myself and couldn't get much more out of them.
The car has only done 120'000 miles and I find it hard to believe the engine has gone at this mileage (I could be wrong). So thought I'd ask here.
Any help would be greatly appreciated.
Hi Russell,
What engine does your Mum's s type have?  Diesel or petrol.
Has the car had regular services?
Did the garage connect an OBD2 code reader to see where the problem is?
I agree with Peter, getting the codes read will help immensely. Having read the scenario I would also check the output from the alternator. The battery and associated cables should also be checked.
Its a diesel  (2.7 i think) and automatic. The garage she has it at is not very helpful at all, seeming unwilling to run diagnostic tests on it other than how it sounds.
Sounds like I need to get it somewhere better :-)
I've read before that a dodgy battery (and associated electrical parts) can cause these big problems. Have you guys had that before?
Jaguar forums are littered with people whose cars have had battery problems that seem completely unrelated. Google is your friend, search for a Jaguar independent Specialist in your area and get the car to them.
Thank you Jimbov8, ive told her to take it to a specialist now.
I will post the outcome incase it helps someone else
Hi Russ,
Jim has been very helpful  ---  a good garage which knows about Jaguars is always useful!
There is one other question I would ask.  You said that your mum's car hade done 120,000 miles --  Has the cam belt been changed?  It should be done at 105,000 miles or 10 years.
ooohh....I will double check with her. Thank you so much guys, its been great being pointed in the right direction.
Forever grateful
