jaguar 2012 xf showing battery not charging message
jon7
dont know how old battery is it doesnt look to old, when i start engine it reads about 14.5 volts after about 30 seconds it drops to 13.8 then the battery not charging messaage appears on dash i dont have a problen in starting and everything appears to be as it should tks
Could well be a dodgy battery.
Do you have a good quality battery charger to see if it can take a charge?  CTek are very good. (really worth getting one if you do not have one as the XF really appreciates a top up once a month (I do mine once a week).
If not I would suggest you get a free battery check at Kwikfit as they are also a good source for replacement if it is dead. They did mine a couple of months ago for £261 but they start at £238.
If you have the secondary small battery, check the voltage of that one also.
