I've got a RH Brake light failure message up.
However, its not the bulb or a fuse  as the bulb lights up but very dim.
Any Ideas??
Welcome to the club, Roy.
I would be inclined to change the bulb. It it is dim it is failing.
I hope you enjoy the club.  There are lot of friendly people to exchange  information with.
I would also say its the bulb --perhaps not earthing enough.????
all the best
Frank
You can guarantee 90% of automotive electrical problems are associated with 'EARTHING' although with light failure sensors there is usually an electronic box involved which works with a resistance value. I have had this problem in the past and swapped the sensor with the other side as a test procedure. But then I'm only an Electrical Engineer auto electrical is something different with the Management Software getting involved.
