Hi all, a bit of a request. I have had my S type 2.7Diesel 2007 model for a few weeks now & I have started looking around under the bonnet/Hood. There are a couple of things not right. The fuel filter is " floating, i.e. you can pick the can up a move it around, there also seems to have been some work on the right hand side engine bay, poss EGR replacement as a few things are loose around theree, the power steering reservior for one. the foil protection and sound/heat proofing on this side are also showing signs of being disturbed.
Finally, and this is where I realy need some help, a vacume line from a sensor on the front of the engine which runs under the manifold was "terminated" I use that term loosly, on the manifold securing stud. i tok the line off & with the engine running there is suction there, without knowing where it should go I had to put it back on the stud.
Is there anyone around in North Herts who would let me see where this line should go, I guess it has a function.
Strangly after proding around in this area the EML went out next time I started the car, I only disturbed the EGR loom and this phanton vacume line?
hope someone can assist.
M
Hi Martin,
I have the same model as you, and although I am not in North Herts you are welcome to have a look under the bonnet on my car, which is quite undisturbed.  [i don't get oily hands and more].
The engine was replaced by Jaguar whilst owned by Stratstone at 21k, and now with 60k on the clock it has only done 39k.
Hi Martin,
I have an 05 but should be the same as yours under the bonnet. I can take a couple of pictures and post them on here so you can see where everything should be if you want.
Gary.
Sorry for the late reply but I will post a few photos in the morning.
Gary.
Thanks for the pic's definately helps around the fuel filter area.
all the best
Martin
