Odour from Air Con
I bought my XE new in May this year but am getting a strong odour from the air conditioning. So strong at times it makes us feel sick. Any one have the same problem? I have it booked in but fear the garage will just say it's normal.
Welcome to the club, David.
I have not come across this before, although I have picked up other odours during the muck spreading season.   I don't think it is normal and I would guess that it is a leak from somewhere.  Air cons will pick up any odours in the air.
Years ago when my company car was a Ford Escort, I used to cook chicken drumsticks and sausages wrapping foil on a biscuit tin  fixed to the manifold.  I could tell when it was cooked!
Tell us what the garage says.
Hi David
Ive had this before, its a damp moldy smell
if you look on ebay, for air con cleaner, you can buy a spray that cleans and kills the smell, I used one on my mitsubishi and it did the trick
you basically put you heater on cold and full fan speed, its best to remove the pollen filter and spray it in there, it sucks the spray in and and cleans the aircon evaporator, thats the little radiator that get ice cold and all the moisture in the air, condenses on, this is where the water comes from when you turn your car off and you get that little pool of water, this moisture can go moldy and this is what causes the smell
there under a tenner usually
joe
I'm having the same problem with my XE, it smells like a stagnant pond.
I solved this problem by having the filter changed to a carbon filter. Hope that helps.
Hi David.
Was that the pollen filter ?
I’m not sure. Jaguar did the job. I’m afraid I’m not mechanically minded
