I am getting rather tired of intermittent  false alarm warning lights on ABS and SRS when there is no fault on my 02 XK8. The car is low milage and well cared for, I do not want to throw any more money at these niggles............My current solution is to stick a square of black tape over them.........
QUESTION.......Can the computer be reprogrammed to switch them off permanently / can the bulbs be removed, or is there a fuse that I could pull out to get rid of these annoyances? As I drove fro long befor such things were fitted, they are not features that I value.
Hi Mike and Welcome to the Club,
It 's never a good idea to disable warning lights in my view - its just tempting providence.
If previous checks of the ABS and SRS systems have categorically proven that nothing is wrong with the sensors and associated parts I would begin to suspect the either the Instrument Binnacle or perhaps the CANBUS. Have you had the car checked out using a Jaguar specific OBD2 code reader? This could provide better clues to whats going on.
Thank you Steve, for your opinion but now I just want rid of the warning lights.
Yes I have had several checks at the jaguar specialist but do not want to throw any more money at it.
Hi Mike,
I am inclined to agree with Steve.  Warning lights can also be affected if the car battery is low.  I have the ABS warning light coming on and then going off, which have been easily and cheaply solved by put the battery on a charger.
  • 8 months later...
Battery.   When you remove the old battery leave it overnight and the lights should reset.  If they dont you can buy a OBDC reading on Ebay cheaply and reset them with that.
  • 6 years later...
I've the same 06 xk perfect car low miles battery fully charged after standing then abs light followed bu dpl then cruise not avb and cat light followed by engine maintenance ight there is nothing wrong with the car no faults at all drives like new just fed up with these lights put obd reader on takes of engine management light off then comes back on wanting to sell now cos it's bugging me
Hi Neil, the symptoms you are experiencing are most likely caused by the battery in your XK. In a modern car, like your XK, the battery's ability to start the car is no longer the definitive that the battery is good, even if you have it fully charged. The reason for the faults appearing and reappearing is the spikes to the 12V system caused by an old or failing battery.
If you fit a replacement battery, the faults will be cancelled and not reappear.
Folks like me consider the battery in my car as a consumable with a life span of just 5 years. Beyond that age, the battery is not capable of sustaining the stable voltages that the car's electronic circuitry needs.
N6 JMX
