Spongy brakes arfter changing reverse into drive. dri
David dparks
Hi,has anyone had the problem of spongy brakes arfter changong from reverse to drive.arfter putting the car into drive arfter reversing the first time i brake in the forward gear the brake pedal goes nearly to the floor to brake,but after that first initial brake its fine again.it an 2015 xf sportbrake.
Sounds like master cylinder starting to fail
if there's no air in the system, nothing else can cause the brake pedal to go lower than normal
would get it checked and get the brakes bled first as air can do this
