Engine only will run on tick-over
stewart bowker
Previous problem - car would not start due to steering lock malfunction - after much checking without and progress I replaced ALL electronic modules  -Ign key and lock - Full dash board display etc all from one donor car (comparable with my cars VIN chassis etc details). Now everything works except once started in will only run on idle - ?? appreciate any help suggestions ect
thanks
strange on, what happens when you press the throttle
have you plugged in a code reader and checked accelerator position sensor alters when you press the pedal
have you tried turning the key to position 2 and pressing the accelerator all the way down, slowly 3 times, before starting it
do you have any fault codes
Good day Joe
Thanks for your very quick response.
Please see below.
strange on, what happens when you press the throttle ( Nothing no acceleration )
have you plugged in a code reader and checked accelerator position sensor alters when you press the pedal ( I have a small unit I purchased from UK but no very good and it is not indicating and fault) A local garage used their instrument which was much more sophisticated than mine but again no fault was seen)
have you tried turning the key to position 2 and pressing the accelerator all the way down, slowly 3 times, before starting it ( I assume that the key in the OFF position i.e. when you have just inserted the key into the lock is position 1 - is this correct) please note presently I am in my office in Vietnam my car is at my main home in Miri Borneo so I will try and get someone to try this method.)
do you have any fault codes (No as explained above Joe)
Many thanks stewart
