I have a 2009 XF Portfolio S 3ltr diesel
The batteries in the tyre pressure sensors are dead and the management system shows a continuous error.  The TPMS is not required for this age of car I want the system disabled.
My local, Telford Shropshire,  auto electrician has the gear to do the work but the codes he needs to alter are greyed out, he doesn't know why and cannot proceed.
Is there anyone here that can advise my electrician what needs doing. Or, is there another auto electrician not too far from (within 50 miles) Telford that can do it?
I would like to get it fixed asap lockdown excluded.  MoT due December must fix it before then
Thanks in advance
also, if there, manufacturer fitted, they have to work at mot or its a fail
if you can disable them via software it would be ok, as long as there are no warning on the dash
you need Jaguar SDD software
  • 3 months later...
Hi Greg ......
 Did you find anyone who could disable it. I'm also in Telford.
I had a local Jag man do mine he deleted them via his kit didn't show up on the local indy machine.
On 5/6/2020 at 4:21 PM, Manniewinaename said:
Is it not just as easy to remove the tyres and replace the batteries?
How much would kwikfit charge for that?
No, the batteries are non-replacable. When they fail then it is a new sensor.
With my car it's the Tyre System Failure.  The wheel  sensors still work
On 8/31/2020 at 8:24 AM, Reh60 said:
Hi Greg ......
Not yet. Jag garage in Wolverhampton thinks they can do it but need my car, got it book in for next month. Going to phone a garage in Halesfield on Monday
Got my car booked in for 21st with a local auto electrician to see if they can cancel the Tyre System Failure warning. Then it wont matter what condition the wheel sensors are in.
My next cat is going to be a mid 1985 model, something with no computers.
Hi Greg ......
Car booked into Autoclinic in Halesfield for Monday 21. I'll let you know how I get on
Where is he? Postcode and phone number please
Posted (edited)
Today I went to Autoclinic-Telford, Unit 3, sovereign park, Halesfield 24, Telford TF4 7NZ
Tel:01952 585555
They managed to turn off the warning message. It seems the NSF sensor was showing an error, I always maintained 2.5 bar in all wheels that's more than recommended. Manager suggested I fit a new sensor. Might fit one when tyre needs replacement or if error comes back
Thanks to everyones help. For the time being afaic this thread is closed
Edited by O.T.H
advertising
This topic is now closed to further replies.
    • Jaguar Icons
      • 11 replies
