Yes you can. I use Millers DPF cleaner in mine.  One bottle will treat about 60 litre of diesel and costs about £8 a bottle.   If you go on the internet you will find a few companies that supply it .
Welcome to the club, Kenneth.
Ian has given you the correct answer.  I  use Millers Eco plus Diesel  [Halfords supply it]  and I have never had a DPF problem over the 7 years I have had my 2.7D S type.
The Millers Eco plus gives a measured dose to each fill up and a bottle lasts about a year, as I do not do a big mileage nowadays.
Hi Peter,
 Would you advise I use Eco plus as well as or instead of DPF cleaner.    Or would this be  considered overkill ??
Ian
Hi Ian,
I would not use two additives at the same time. I think it would be overkill.
Both additives are good.
