I bought a 2012 XF a year ago. Shortly after the camera stopped working for a couple of weeks, then started working ok again. Then last week the wipers went crazy. They eventually stopped altogether. I had to pull over and turn off the engine, then after a couple of minutes they started again. Now this morning the camera has stopped again with the dreaded "refer to dealer" message. The loom in the boot seems to be a frequent problem but I'm wondering whether, given the wiper issue, it might be the battery?
Battery problems tend to lead to spurious warning messages. I have never heard of wipers going crazy due to low battery.
There may be water getting into the electrics somewhere. I don’t know which model XF you have, but have you checked the spare wheel well in the bottom of the boot?
I assume that you are referring to the reversing camera. Check the wiring between the body and the boot, where it flexes on opening/closing. This can crack due to the repeated flexing.
Had a look in the boot - no sign of water ingress.
I'm assuming the wiring to the loom in the boot is within the rubber piping from the lid. I'll take a look in there.
Incidentally, the wipers are now working properly. For now...
I tend to agree with Leo --Battery problems tend to lead to spurious warning messages--
Battery on way out ???
Latest update - camera, sensors and wipers all working properly. I have no confidence that will last. I'm thinking it's time to sell it while the selling is good.
