Eml light with P1646 OBD error code
ely.gedt
Hello all,
I have a 2002 x type 2.0 petrol
The engine fault warning light is on
Error codes P1000 and P1646 that indicate Bank 1 sensor 1 fault.
Found it had an o/C heater. After replacing and resetting error, the light still comes on after 15 seconds or so
I took a screenshot of my OBD scanner monitor. See image
Any ideas?
P. S. Changed B1S2 sensor as well
P1000 is normal after code reset till its done a full drive cycle then will clear on its own
P1646 is a bad lambda, are you sure you changed the correct one, if the faults still there
also on the S-type, cheap lambda dont work, only denso one seem to work
    • Post in Event Ludlow Racecourse Shropshire 19th May 2024
