Jaguar XF electronic gremlins
I have owned a 58 plate XF for 18 months and have been delighted  with the car with the exception of the electronics which continue to play up occasionally.
For the first 3 months of ownership the car was almost impossible to lock on the plipper without the alarm going off and also starting was a problem intermittantly.One Jaguar garage claimed never to have seen the fault before although they claimed to have sorted it .
Then after 3 months the car began to behave normally as if to accept me as the new owner (I know it sounds daft).
Recently ,however , it has started repeating the problem ,both when locking and starting and I am beginning to lose faith in what otherwise is a superb car.
Honest John referred to electronic problems on early models and I wonder whether any other owners have encountered this problem?
Howard Jones
I would make a start on checking the connections to the battery and the earth connections to the body...
Welcome to the Club, Howard.
I had heard that electrics were an issue in the early models.  A friend of mine used to change his car [usually a Ford Cortina] every time a new model came out --  but unusually for one of the last of the old model.
I hope that someone can assist you with their experience if similar.
Peter
Many thanks ,I hadn't thought of that !
Howard,
I would borrow a new battery if possible, and go from there.
Quite often things not working properly is a sign of the battery on the wane.
But whatever the problem, I hope you get is sorted shortly.
ATB,
Trevor
