changing steering wheel on my jaguar s type 05 2.7 diesel it says disconnect battery but when I do that the steering lock comes on so I cannot access the airbag studs
Hi Brian,
Have you tried the videos on You Tube might be worth a look
Kind Regards,
Julie.
  • 6 months later...
I just followed a Youtube video, Perfect, took less than an hour. It was a couple of years ago so I don't remember the order but one thing I did find. Make sure the horn pressure is the same on the wheel you are fitting.
