Hi everyone, im new on here but have a question that is not just confined to jaguars,
A friend of mine has been told that adding 2 stroke oil to the fuel will help it run better, I have never heard of this before so if anyone can help clear this up before he goes ahead and does it I would be grateful, he has an audi diesel
Thanks in advance
Kippers
hi david ive known people to do it but if it was my car i wouldn't tbh
this is only my opinion mind you
Hi David
This is just my opinion--I think it would down rate your fuel and cause it to smoke so I would not use it .
Frank
Thanks for the quick response guys I've passed it on to him but I think he's still going to try it, personally I've never heard of it and won't be try it as my car runs fine, thanks again
Kippers
Hi David,
I have known several  X type diesel owners who mix 2 stroke oil with another additive --  Millers, I think - whenever they fill up.
They also used supermarket fuel, which most diesel users find cheaper but less efficient.
A lot of thought has gone into what the oil companies put into their fuels, and I think that the amateur fuel fixer has a long way to go before getting to the stage when their mix of oils and additives is as good as Shell Vitro which I use [the nearest to me at 500 yards], BP and Esso equivalents do exist.
I always advise the best stuff, as the engines are performance engines and need performance fuels.
Thanks for that peter I won't be doing it, but I think my friend has got it into his head to try it on his audi
