My front tyres on the x type awd have worn on inside after only 12 months. The suspension has been checked all over and is solid. I can only think the pressure is not right. Is this a common issue? Tracking is spot on too.
Hi Mike,
I have not come across this too often, but I would check the tyres regularly, as I do.  The pressure for the s type is on the right hand side pillar when you open the door is it is likely to be the sam on the x type.
Hi Mike,
I had an AWD 2.5 litre on an 05 plate also and never had a problem with uneven tyre wear.
Tracking might be ok but camber or caster might be out
I have used kwik fit, certain depo's have 4 wheel alignment, cost me £50
but they did a cracking job, print out for before and after
    • Jaguar Icons
      • 11 replies
