Gearbox oil leak on prop seal
piria33
During an Oil change today we noticed a slight seeping from the seal to the prop shaft.
Looks fairly new.
Was planning to get the fluid changed very soon anyway.
Is this the correct seal?
http://www.xjkltd.co.uk/jaguar-s-type-automatic-gearbox-output-shaft-extension-oil-seal-xr85804/
I'd get changed as soon as, as the Oil level is quite critical on the autobox
you can look on SNG Barratt, for part number but I'd phone with a vin, as they may be different from year to year and engine to engine
there not expensive and quite straight forward to change
