Hi All,
Just acquired a 2006 S type (Automatic) - it seems to be a good one - although there is a slight missing on tickover - also as the mileage is quite high -90,000, should I have the gearbox Oil changed?
Martin
As above, I did mine for peace of mind
also check your sills, there hidden by a plastic cover and they can completely rot away
might be worth also getting the plugs changed if its got a misfire, first place I'd start
Joe.
Welcome to the Club Martin.
The gearbox Oil is supposed to be for life, but most drivers change at around 60k to 70k.
My s type has 77k on the clock but had a new engine at 28k so I have not had it changed yet, but I will in 3 years time.
15 hours ago, Essex Fat Bloke said:
Hi All,
Just acquired a 2006 S type (Automatic) - it seems to be a good one - although there is a slight missing on tickover - also as the mileage is quite high -90,000, should I have the gearbox oil changed?
Martin
Hi Martin,
i bought an icarsoft diagnostic tool which has proved a great money saver in terms of identifying faults so i havn't had to buy parts i didn't need.
I had a misfire on my V8 and plugged it in and it identified a coil pack failure on cylinder 1.
I have also used it to check any historic logged codes.
Just had the ABS light come on and the tool has identified left rear speed sensor.
Enjoy the car.
Graham
Hi Graham,
Just out of interest which iCarsoft scanner do you have?
20 hours ago, cubist said:
Hi Graham,
Hi Steve,
its the LRII.
Graham
I'd also add my endorsement of the LR2 Saves a lot of time rather than setting up the SDD / IDS. Very useful test equipment
