Hi everyone,
having gone through the diagnosis and replacement of the DCC Valve and the air con panel i am now getting the fault code
P1642 = Air Con Pressure Sensor Circuit Low Input.
Would anyone know the proccess to locate the fault?
I am also getting J1850 which i think maybe its coming up because of the P1642.
Any help would be most grateful.
Thank You,
Graham
where did you get the code description from, P codes are usually engine faults
and in jaguar JTIS for a 2002 s-type it says this
4 hours ago, JOE-DOT-COM said:
Hi Joe,
thanks for the reply.
I had tried to edit my post and delete because i had posted up the incorrect code.My apologies.
The fault code is P1462=Air con pressure sensor circuit low input.
Graham
Hi Graham,
Nice to see you posting.
Are you coming to the JOC meet at Lancaster Jaguar Tamworth next Sunday -  The 22nd July.  Just off the A5.
5 hours ago, Old Peter said:
Hi Graham,
Hi Peter,
i would like to come and are aware of the meet up.
My other half is away on business at the moment so the next time we talk i will mention it.
I will confirm either way as soon as i can.
Graham
Hi Joe,
Are you coming to the meet atLancaster Jaguar Tamworth on Sunday?  It should be a good day.
Correct, Joe. The 22nd July.
There are some members coming from long distances  and with a bit of luck there should be about 20  members there.
I also think that there would be a few questions to those who know about electrical issues -- getting key fobs to work properly etc.
Hope you can get there.
Hi Peter
Normally I would love to go any meets
But unfortunately I away Friday on hols in caravan, so will have to give it a miss
but If I'm back early may attend
allways on here for any help on S-type's
Enjoy the weekend, Joe.
We retired from caravanning 7 years ago.  I still miss those weekends away!
On 7/16/2018 at 3:06 PM, Old Peter said:
Hope to see you, Graham.
Hi Pete,
just to let you know i am unable to make Sunday.
Have a great day.
Graham
