Can any one help 2006 2.7d
went over a bump lost phone cdc link and voice on sat nav,radio and sat nav still works , checked eject+mix just says main so assume joint apart somewhere can somebody tell me please where to look
thanks
It could be anywhere in the D2B network. Any break will cause total failure, which is what you have.
I'd start behind the stack in the boot  (trim panel out and unbolt the stack from the boot floor) or if not then the back of the touchscreen.
Have checked connections both ends and all connected ok, there must be some joints somewhere, as to be that as all fuses ok, somebody must have encountered this before.?
thanks
Disconnect each D2B module one at a time and substitute a loop terminator. This will eliminate each module in turn. If not a module then a fibre optic cable break.
Thank you
is there a cable layout for this which shows the cable travel through the car, alternatively the exact whereabouts of all the modules,
aa a side my phone still picks up the Bluetooth.
Perhaps this lot may help if not it will still be fun going through it ?? Ha Ha
  • th?id=OIP.78rprjmKyQLk1uZd8uldpQHaEv&pid
  • th?id=OIP.Tec8mocf5GJOQPK6DKCQHQHaFV&pid
  • th?id=OIP.JzoVm_VGx0olZhRehKu9HAHaFU&pid
  • th?id=OIP.4vOwD3YCR9pmFVUG4uf1UAHaJQ&pid
  • th?id=OIP.g4QOEuKISfK_5Xvc883A2wHaEw&pid
  • th?id=OIP.In-vo8BDvs72ozCamZGmbgEsDE&pid
  • th?id=OIP.tsBaCSuonr7uEA4XcapOhwHaFO&pid
  • th?id=OIP._TtrI8OEbpG6XPOIHaZjpgHaFM&pid
  • th?id=OIP.wVY89w00MS863ifa3upnwAHaEb&pid
  • th?id=OIP.ZiMsiRAcNNhlZ7XJX5XBzQHaFj&pid
  • th?id=OIP.nzbd3jVmpnNJVrtq_WojVwHaGO&pid
  • th?id=OIP.o4O1y2alf3V3qHFxEbTJvAHaEa&pid
  • th?id=OIP.pdhGE66CroCOzbsQEM4ZBwHaGw&pid
  • th?id=OIP.Zi__kYhK6b39izfTEsTfLwHaFO&pid
  • th?id=OIP.oW7umX3HA0PDhvIEhCK61QHaJN&pid
  • th?id=OIP.0QmQvdFf8kRt63fhW8D-mAHaFy&pid
  • th?id=OIP.w7oK2Q51CaCVzZzHfDLHFwHaFV&pid
  • th?id=OIP.UMx8RYuZHsS9iDwOFg8F7gHaFu&pid
  • th?id=OIP.lDduCQ6nALX7rrV-qL99ZAHaGB&pid
  • th?id=OIP.8BQTUuzLZJ4nFao5syaYvAHaKH&pid
  • th?id=OIP.tG_NCF2CGNAjNDVImvz21wHaFx&pid
  • th?id=OIP.FdsJgqEoWXNx77ItL-V82wHaE9&pid
  • th?id=OIP.t1tWiT3uv8p783PZB9n7swHaFt&pid
  • th?id=OIP.rtc1pwPuyXYOj9eNvAUbwAHaFy&pid
  • th?id=OIP.J2DR-vma6FVzAssES00j8QHaEK&pid
  • th?id=OIP.7E8iqSzSi1BAs1fErZgqVQHaJZ&pid
  • th?id=OIP.bYlpRi_dWMimxAu9LyUVlAHaE1&pid
  • th?id=OIP.mHEpCzBbHH-iv5LzSFEidwHaFp&pid
  • th?id=OIP.OZVrCAExDUP6D9fV31znDQHaEK&pid
  • th?id=OIP.3Cer0rr_xC9Q_IIxFMR5XgHaDy&pid
  • th?id=OIP.pXP_GRyq8Ff87tVOYfzCRQHaFO&pid
  • th?id=OIP.2Xwlbn46n2dMu1IwHLS0dQHaJ5&pid
  • th?id=OIP.Qgn2N7QvMbyhBmbUUQAIPgHaIw&pid
  • th?id=OIP.dpS8I6KDgbkykjawS_W4lgHaGX&pid
  • th?id=OIP.HumO-g2ujDC5qqLsb_SMbgHaKd&pid
  • th?id=OIP.y7v74YjRr1U8TJ9TdXPa3AHaFL&pid
  • th?id=OIP.1hlyYR_I4ZZEcy85qI_hfAHaD_&pid
  • th?id=OIP.c_qds7S10u1jqRpm0tASYAHaGC&pid
  • th?id=OIP.lOuBrJ0ljQWte3cLGVd5YQHaD7&pid
  • th?id=OIP.beQ92z00mSool8_6BHBYIQHaEZ&pid
  • th?id=OIP.pbmMRl8cG8x6IrhDR1p7XAHaD_&pid
  • th?id=OIP.k9jW9MbrEMYcF5gW8hjEBQHaFe&pid
  • th?id=OIP.0L21dNojs3kruL-QFcAVXgAAAA&pid
  • th?id=OIP.f48nOSMAVSdfJm2PALDd0QHaFV&pid
  • th?id=OIP.-Y1V-nS-G6wshFoyhxx7TwEsCa&pid
  • th?id=OIP.nPwwwfcEfkM2FHJohDu1fwHaEy&pid
  • th?id=OIP.z4C0opPdK6i4peM9FnxlRQHaEv&pid
  • th?id=OIP.khH__nie0dMNeafMWsj0SgHaJ4&pid
  • th?id=OIP.qG7ZTUzijq1xwSxUyCqokQHaFj&pid
  • th?id=OIP.7J9hQUsS1WbxEhsoSd5DgQDcEb&pid
  • th?id=OIP.YJOGLJ7lJzNNo8axEbUT-QHaKJ&pid
  • th?id=OIP.ijyjQpXVkjj5CjPp115jSwHaFt&pid
  • th?id=OIP.uurfpfAvzGxLbyDgwPnXDAHaEv&pid
  • th?id=OIP.GTBEB-qKjpkPywhSssx-PQHaFI&pid
  • th?id=OIP.L2NjfTWJGg0GSmZaSghxqgHaFj&pid
  • th?id=OIP.VjdfkEW4D-62p8aHQIROlgHaGz&pid
  • th?id=OIP.IyY51Qk27D93Tqlny4-3KwHaEh&pid
  • th?id=OIP.KJzFxtYlUe2vc5zgw5rWhAHaFO&pid
  • th?id=OIP.v9kga2zuo7kh0FlKbVx6zgHaJA&pid
  • th?id=OIP.Q07xCj-FeaN-hxS4sEvbTgHaGw&pid
  • th?id=OIP.0NhjY_enf2vQsiW3xIDfbgHaFm&pid
  • th?id=OIP.anQGFy0nitaC18-kxFgGmAHaEo&pid
  • th?id=OIP.nWJXXjCTH1eMGZK3RG0QHgHaGB&pid
  • th?id=OIP.V-ebvcN0DqbEZZiZpluegwHaFs&pid
  • th?id=OIP.UWevRo_8Kdwkh48ikDlcBgHaFU&pid
  • th?id=OIP.CSDnoJDzKYRNzRWSQrcj9gHaD8&pid
  • th?id=OIP.mgnQm2LccBn4vA8krOUvHAHaFO&pid
  • th?id=OIP.YcMn_kQylJLjNEtOLBXWVQHaFh&pid
  • th?id=OIP.IHKrIgzZnlmWEIjDB0nObAHaE1&pid
  • th?id=OIP.f1y9oyY08CiakQF1fheyiwDnEO&pid
  • th?id=OIP.RCz2_booQt668UkcBX6dsQHaGP&pid
  • th?id=OIP.JqxXseD4Nf6KbWvZDDfoNQHaJC&pid
  • th?id=OIP.XDloYykw8P04CK0Mbv9EjQHaFj&pid
  • th?id=OIP.o-78eFyuJqsxm7bDerF8ugHaFj&pid
  • th?id=OIP.4204GKBstgO_02s9r7JNjgHaMg&pid
  • th?id=OIP.8yAfyPFlXlztKB97dtxERAHaEw&pid
  • th?id=OIP.39hQ4Fh8p0pzNy_T2d10qQHaJy&pid
  • th?id=OIP.bsl0xjSQqAmR-chP9U5ACAHaD8&pid
  • th?id=OIP.GjKHiwnE3sB8eIoXvIxY8gHaFC&pid
  • th?id=OIP.TqiIu_CeY5ooiUlojet22QHaJE&pid
  • th?id=OIP.-kobgVzQUu9n742bHtnjtwHaEm&pid
  • th?id=OIP.qPeakp1PvbToHT66LKy7dAHaJl&pid
  • th?id=OIP.iaqXge5_HT5rxfSEXo5wsAEqEs&pid
  • th?id=OIP.SirbWNkfgeH026hJsmC7KQHaF8&pid
  • th?id=OIP.8uNTeUoldkUxGOP4uYQdwwHaFj&pid
  • th?id=OIP.72f_wOGRuN8nye4-tO17gAHaFe&pid
  • th?id=OIP.OjqA31y8j10Bvdz-oXT9IQHaDw&pid
  • th?id=OIP.zmqpd7osY5MhANpZmdD4iAHaFP&pid
  • th?id=OIP.Z8fwFRqekY5C-nbBB0z-1gAAAA&pid
  • th?id=OIP.Ec9zS6P7QuVmS27F0SbhXwHaFO&pid
  • th?id=OIP.IcogDWipjCW2zpw600ccKQHaH8&pid
  • th?id=OIP.TkxY12UdfWmgQ8Q26LgOcgHaGq&pid
  • th?id=OIP.TT4X8Mwum-jSj8T17x2jswHaFL&pid
  • th?id=OIP.E3-q0YqYlbFO_CC-oQHkVAHaFc&pid
  • th?id=OIP.uCtntTdsKbKqQeNsTv72ugHaKl&pid
  • th?id=OIP.jEpBvFFUAOkuFVHJeoV37QHaE-&pid
  • th?id=OIP.NjOPex9LidBZ8q63mQwgJgHaFO&pid
  • th?id=OIP.ktgCjBOFhfuqsz7fdr-iPQHaEF&pid
  • th?id=OIP.qPlAj-ZkkKZoLTLNVlt50QHaJ4&pid
  • th?id=OIP.7NS3bHMl9oa7d6BflIQZ4QHaFy&pid
  • th?id=OIP.XQ77sIbDKzkKwTJZKFew9wHaDt&pid
  • th?id=OIP.mPkA3uqr-X20sTg7s5_wnQHaEy&pid
  • th?id=OIP.6rsGm32iuqFpMLr088YJuAHaGi&pid
  • th?id=OIP.YFk7mcJ9rdqFyu_w5PdSVwHaJJ&pid
  • th?id=OIP.lgagYZ_YRjfXGviI_f0ntQHaFY&pid
  • th?id=OIP.OvdF-h6NunvOC0IB7ZM_AQHaFB&pid
  • th?id=OIP.aoMlpG9E425zW1VYMGQSGgHaEV&pid
  • th?id=OIP.bWx9TueYqZjwM4yj-P834AHaIb&pid
  • th?id=OIP.rXwLKgyCBbmNvy9zP6GDWgHaFu&pid
  • th?id=OIP.cWNkPGs3AKgWU3Knf8s6hwHaFj&pid
  • th?id=OIP.XL_9YzH0h1-_ksI6anZfQwHaFo&pid
  • th?id=OIP.tiBW31FdG1IpU0hoGO7oHQHaJF&pid
  • th?id=OIP.JJYXN9_Sn_sWl6ehopGluQHaGF&pid
  • th?id=OIP.Jsa3J9WKvqp-iDS8V8ml1AHaEK&pid
  • th?id=OIP.NL4t-d0G-0y1i64WSL-yJQHaFM&pid
  • th?id=OIP.CGfmFpR_nKkWcl8Zivk5SgHaF0&pid
  • th?id=OIP.C33Su0PyaWiOv1BT2R7-mgHaHY&pid
  • th?id=OIP.bj6AX3-tw9m8Z_JAAvB_ywHaD7&pid
  • th?id=OIP.eWYqabp2lKEwLvUuRIabIQHaFF&pid
  • th?id=OIP.2I9kb7DsVPTD5VNXuIJFeAHaJi&pid
  • th?id=OIP._Mk3elD6l0DkdDhjKuHi8wHaHe&pid
  • th?id=OIP.VztS-jSh5HPnc0QOwVXSkgHaEK&pid
  • th?id=OIP.0cROUzv-OPp78YMpSZFZrQHaKI&pid
  • th?id=OIP.saBoX4bHUpPrV-EjmQL6NAHaFJ&pid
  • th?id=OIP.j7cp3Nx4I6OfRI15HtC2NwHaFN&pid
  • th?id=OIP.qX95JY8raaKmWJQXdqgTggHaI8&pid
  • th?id=OIP.vF2s6b8Ga4Q-iNMTwsD8RwHaKY&pid
  • th?id=OIP.VMXqTP5sgjbsLUFwOcrK0AHaFg&pid
  • th?id=OIP.5_1gNeDpn32-yNWKkp3PNQHaFs&pid
  • th?id=OIP.g_CzNXXX7XzamH9MGU4KQwHaJR&pid
  • th?id=OIP.Jno7dwoAjiygZ58mTBhnYgHaFp&pid
  • th?id=OIP.3ua5B6kdk1hdFwH6rwgqAgHaIU&pid
  • th?id=OIP.MEojukiDgErDzQlXOLdN7QHaDy&pid
  • th?id=OIP.W-Y5-oedDTTysvzuQoq6uAHaFa&pid
Footer
Yahoo Powered by Bing™
Thanks for all the help reading "my stuff" d2b guide, I have in my boot when I undid the cd and nav units a loose d2b  spare cable and some grey blocks should there be some sort of link on the d2b cable to allow the loop?
It's clear you haven't got premium sound Peter.
Therefore, if that D2B connector is in circuit it will have been terminated with a loop. If so the loop has possibly fallen off and is floating around in the stack cavity somewhere.
It will look like a loop of fibre optic cable inserted in a connector.
If not, have you had the Kaiser panel out? That's the silver coloured panel in the background of your first photo. There are D2B connections on the back of it.
Paul
Thanks for you help I have attached a rough drawing of the connections, not sure what the unit is between outer and inner wing it also has connector block going from it
In which case that blank D2B connector needs to be terminated Peter.
As your shystem was working I can only assume that the terminator must be in the car somewhere.
The module behind the panel that you are not sure of is the Voice module.
Paul and others that replied SUCCESS
After stripping out half the car, there was another unit in the boot behind the bright metal plate. The voice module was at the top end, this module was at the bottom end found it by accident feeling around, after removing the sat nav/cd. The grey blocks I assume must fit something else, the optic cable had fallen out of that clipped it back in and all working.
really appreciate the guidance
Peter
The other module is the phone module Peter.
Pleased you solved it 🙂
Perhaps now you will fit the premium sound system 😉
You never know, do you have a link to say what you need.
  • 9 months later...
On 8/16/2018 at 5:01 PM, Raistlin said:
No, but I can let you know if you decide to go that way.
Paul
wht would you need to upgrade to premium sound
thanks
peter
11 minutes ago, Raistlin said:
Amp, door speaker, parcel shelf with subs. a D2B cable
Thanks will keep eye out
13 minutes ago, Raistlin said:
If you want, I can look out for you. What colour parcel shelf?
It’s called warm charcoal grey/black
thanks
  • 3 months later...
