I recently changed the engine Oil & filter, air filter & fuel filter. My next job will be to change the spark plugs. My question is, what do I do about the inlet manifold gasket? Apparently a new one cost about £70, but it doesn't need changing if it's still OK. How do I know if it's OK without removing it? Bit of a 'Catch 22' situation. I buy a new one & don't use it, or I don't buy one & the car's off the road for a week till I get one & finish the job.
Andy, surely the inlet manifold gasket isn't a service part?
In which case, I would leave well alone if the car is performing OK.
If you need to remove the inlet manifold it will need a new gasket there is no point in refitting it because it will already be compressed and won't seal correctly.
Thanks everyone, I am taking Michael's advice & buying new gaskets. Has anyone done this before? If you have, which gasket is it? There's a Jaguar S Type Inlet Manifold Gasket XR843536 & a Jaguar S Type Upper Inlet Manifold Gasket XR85294.. Both at Berkshire Jag Components. Or on Flea Bay .JAGUAR S-TYPE 3.0 V6 INLET MANIFOLD GASKET. PART- XR85398...
post-7880-0-51179000-1442814813_thumb.jppost-7880-0-55713700-1442814829_thumb.jp
