Low Battery - Please Start Engine message
Jon Hyde
Hi All,
My 2017 XF 3.0D S nudges me most mornings, telling me the battery needs charging. After a run, all is well, for a day or so.
As a result, I think I need to invest in a battery maintainer/charger, but which one? Or shall I just ignore it, as the car never actually struggles to start?
Hoping for thoughts and recommendations
Cheers!
Jon
Hi Jon
If it is still on its original battery it is probably due a replacement which I am afraid is not cheap as you must replace with the correct type which is probably an AGM rather than a wet cell or "normal" lead-acid battery. I would get the current battery checked first to see if it needs replacing, but then invest in a ctek. I have this one https://www.ctek.com/uk/battery-chargers-12v-24v/ct5-start-stop-uk .  This is really easy to use and optimised for AGM batteries.
J
So...
Got the battery replaced at KwikFit, £260ish!
Halfords wouldn't touch it as it needed "coding".
Only problem was having to reset a few settings, but not really a hassle.
Now I have to remember to disable the dreaded start/stop nonesense though!
J
