Jaguar S Type dumping petrol
Dave1969
Hi my s type is dumping what smells like petrol when I'm idling/stationary...only seems to do this when engine is running and I'm stationary. Also air con seems to be smelling a bit like petrol to at times and seems to not work on accessions...could the 2 be linked? does air con use petrol?...hoping someone can advise before i just put it in garage thanks
Hi Dave, and welcome to the club.
I would guess than there is either a leak in the tube from the petrol pump to the engine, or a bad connection.
The climate control will suck in the air which is "perfumed" by the atmosphere, whether petrol, fresh air, or fumes from a 'bus,
Tried it again today without air con on did around 20 miles and no smell, no leak...nothing...turn air con on and if i remain idle within 10 minutes there is a strong smell of petrol and what seems like a small waterfall of fuel coming from approx.  underneath passenger  sill..its defiantly petrol and not gas (I'm on both) and it only happens when air con is on
Thanks Dave
Hi Dave,
A bit curious, but a leak is a leak and has to be check out.
Now you have found where it finishes up checking through the route till you find the offending leaky bit curing it should not be too difficult.
      • 5 replies
    • Jaguar partners with Andersen EV for luxury, customisable home charging
      Owners of electrified Jaguar and Land Rover models will be able to charge their vehicles at home with unrivalled style thanks to a new agreement with fellow British company Andersen EV
      Owners of electrified Jaguar and Land Rover models will be able to charge their vehicles at home with unrivalled style thanks to a new agreement with fellow British company Andersen EV.
    • First production Jaguar C-Type Continuation ready for customer delivery on landmark anniversary
      Jaguar Classic has completed building the first C-type Continuation. The strictly limited production run is well underway at Jaguar’s Classic Works, Coventry, and the first vehicle has finished shakedown testing ready for delivery to an excited customer
