The driver's side window air vent, the one mounted on top of the dashboard, rattles at low speeds in my car and is really annoying.
When i touch the vent grille the noise stops.
My question is, how is the vent grille removed please? I don't want to attack it with a trim tool unless that is the correct way.
Probably one of those things the author did not research. Obviously it can only be a push fit whereupon it as locating lugs or it is secured from below which would make it extremely difficult to get at which I assume will be the case. Good luck Paul
Hi Paul
I found someone who had the same problem with a X Type  and here's what he said  :-
icon1.gif                Dashboard rattle
I had the same rattle on my x type and it turned out to be the vents on top near the screen.i just put a couple of spots of superglue
on mine and this  cured the problem.   ?????
Frank
Thanks Frank :)
That might be the way to go, but I think I'll try and get the grille out first to see where the problem is. I really don't want to damage it though.
Excellent Frank, I assume from the photograph that its a simple push in for fixing however to remove you would need to get your hand in be hid it to press the clips inwards for removal
Thanks for the picture :)
What I might do is push a very small piece of foam tape under the lip and see if that quietens things down a bit.
Blu Tac - the perfect solution.
I've just been out to try it and it works :)
Happy bunny me :)
Thanks Peter
