Rear Parking Sensors bleep in wrong gear!
CBers
I have just purchased a 2nd-hand 2006 S-Type SE D Autom, but it has a problem with the Rear Parking Sensors.
When in reverse, there is no sound when near to the wall/fence on my drive, but when in drive and neutral, they beep !!
Any ideas what the matter could be please ??
For now, I have disconnected the Parking Assist box in the boot, but I would like to get it fixed as soon as possible.
Thanks in advance.
Sounds like a fault with the unit,  have you any water entering the boot area ?
My old one made a continuous noise in drive after failing, I replaced it with a one found on E bay, you could try removing your unit and spraying with WD40 or similar but suspect the unit has failed, they are not difficult to remove but i found it easier to remove the spare wheel to gain acess
best of luck
Spannerman - now why does that name ring a bell ?!?!?!
There is a little moisture in the boot where I think the valeters steam cleaned it the other day.
The unit itself does seem sealed OK, but I will try some WD40.
One of the sensors are physically pushed in about an inch on the rear bumper, but the other 3 are OK.
Mine bleep in traffic if i get too close to the car in front or a car gets too close to my rear bumper regardless whether i'm in gear or neutral. I thought that is what they were meant to do. I can switch them off from the roof console.
I only have read sensors.
I have tried spraying the unit with WD40, but still not working correctly.
I've found a "tested and working" module on e-Bay, but the number on it (4x43-15k866-AE) seems to be for an X-type rather than an s-type, although it;s the same as the one on mine.
Do the models use the same thing ??
    • Post in Event Ludlow Racecourse Shropshire 19th May 2024
