Skip to content
CD Multichanger
I only have the single CD player in the centre console, bit of a pain.  How easy is it to fit a multi-changer in the boot?  Is the wiring loom in there somewhere and if so is just plug'n'play?
Gary M
The wiring should be all ready there
there hit and miss, some work straight away and some need setting up with SDD software
you might need a different d2b optical lead, but there usually is a spare d2d lead, with a link lead in
If you do need a different d2b cable, I can probably assist Gary. Also happy to set it up using SDD if it is needed and you're in this vicinity.
I swapped out a CDC as I had a missing cartridge and it was very simple, but this was a straight swap and already had the leads and bolts in place...
Sorry for the late reply folks, work gets in the way sometimes.  Off for a week now though.
Well had a good look underneath the parcel shelf for a loom of some sort but nothing.  Am I looking in the right place?
Gary M
Here's what I have N/S boot.  The small connector has 3/4 pins?
Gary M
Gary M
Thought I'd submitted this yesterday Paul, it was just sitting there???
Gary M
hard to say from that picture
look more towards the rear, more towards the rear light
the connectors are tapped up some times with a foam tape, to stop them rattling
have you a wider pic of that whole side
joe
30 minutes ago, JOE-DOT-COM said:
joe
I'll try again tomorrow Joe, but that's about it.  What does the connector look like?
Gary M.
The small black connector could very well be the power supply for the CDC Gary.
As Joe says though. Need a wider view.
HI
Look under that foam, it might be taped over
top plug is the fibre optic, bottom plug is wiring
the connector is only small
the fibre optic d2b is a loop, so basicically you have to extend the loop to include the multichanger
joe
Removed the foam to find what appears to be a large connector?  Wasn't able to open it as it seems to slide somehow?  Anyway it looks as if I have what is necessary, what do folks think?
Gary M.
No Paul
Gary M
No problem Paul.  Never mind.
Gary M
I's sure its got one, its usually higher up
take a wider picture of that area
why would it have one and not the other
I'm sure its the one arrow in red
it will have a link in it if there is no where for it to plug into, may also be tapped over
we need a wider picture!!!
the suspense is killing me!!!
found a better pic
I have arrow on the d2b connector and cable
Yep. If there's a D2B cable in situ Gary, CD Changer is certainly on :) I imagine it will have a loop terminator on the end.
Presumably, you haven't got a cradle (the black assembly in Joe's previous post?). In which case you'll probably have to insert four riv-nuts into the floor of the boot, to hold the cradle. That's easy enough though and I've got the correct tool if needed.
As Joe says, really need to see what's at the end of that grey foam.
The connector you're looking for looks like:-
It may, or may not, be connected to a terminator (loop of fibre optic cable)
Will do a bit more digging tomorrow.
Ta for the advice.
Gary M.
Isn't the thing in Joe's picture a DVD for the satnav? In mine the CDC sits in the gap below this and I thought it connected with the below connector.
I had a quick look but cant get to it without removing the trim, but does the CDC need the D2B cable, or the one pictured?
The CDC needs a power supply lead and a D2B connection Russ.
